Hi, I am trialling TypeTool DEMO attempting to create a glyph. I opened up a Glyph window and used the Import>EPS dialogue, the EPS imported but it was inverted.
I opened the EPS file (in Illustrator on MacOS) and inverted it to ensure it would be RWU when re-imported.
This time the EPS wouldn't import, error message appeared. I created a new simple, test EPS and that wouldn't import either - is this a feature of the limited DEMO install or a problem with the app?
I see there are similar questions on this forum but they're unanswered.
TypeTool looks a good product but I can't risk buying it if the first job I attempt won't work, hopefully the support is good?
Thanks in advance for any help.
