| Forum
Apps
Buy!
Support
Forum
Blog
Contact
About us
Toggle navigation
Forum
Forum
FontLab 8
FontLab Studio 5
Fontographer
TypeTool
TransType
Staff List
Forum Stats
FontLab 8
FontLab 8
FontLab 8: Python scripting
Login
Register
Help
Alerts
See more alerts
Alerts Settings
No Alerts
Search
Advanced search
Register
Login
1 Hour
1 Day
1 Week
1 Month
Forever
Password reminder
FontLab products
TypeTool
Login
Learn how to use the forum
Feature block seen before any language system statement
Discussion started on TypeTool
Send this topic
Print
Pages: [
1
Go Down
salient
Status: Offline
Jr. Member
Hi support people!
What does this error mean, and how to avoid it?
#1
- 2014-01-20, 11:07
Re: Feature block seen before any language system statement
Alex Petrov (FontLab)
Status: Offline
WWW
Support+Docs, FontLab
Global Moderator
Hero Member
This is not the error but the warning. It appears in Fontlab Studio but should not appear in TypeTool. You may ignore it completely.
#2
- 2014-05-29, 02:35
Although we do try to track bug reports in the forums,
a much more reliable route is to use our bug report
form at <a href="
https://support.fontlab.com
">support.fontlab.com</a>
wyattisimo
Status: Offline
Newbie
I'm getting this warning in TypeTool 3. I tried placing the definitions at the beginning of my FEA file, as suggested by this FAQ:
https://store.fontlab.com/index.php?option=com_fss&view=faq&catid=4&Itemid=430
Code:
[Select]
languagesystem DFLT dflt;
languagesystem latn dflt;
...but every time I export a font, it seems to rewrite the FEA file and clear out the language system definitions. How can I fix this??
#3
- 2014-08-22, 09:28
Last Edit: 2014-08-22, 09:30 by wyattisimo
Status: Offline
WWW
Global Moderator
Hero Member
TypeTool doesn't support fea files compilation and it has limited support for OpenType. The FAQ item you refer to is for Fontlab Studio 5.1/5.2. All you can do in TypeTool is to ignore this message and forget about features.
#4
- 2014-09-11, 03:23
form at <a href="
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
FontLab products
TypeTool
Members:
0 Members and 1 Guest are viewing this topic.
Policies, Terms and Conditions
