Introducing updated release of TransType 4 (v 4.0.1) for Mac OS X and WindowsTrial modeIf you hadn’t installed TransType 4 before, you can download it and use it in trial mode for 7 days (without any functional limits). After the trial period has expired, you need to purchase a license.
Download TransType 4 for Mac OS X and Windows<a href="http://www.fontlab.us/downloads/installers/TR4MacFull.dmg">> Download TransType 4 for Mac OS X</a>Version 4.0.1 build 5099 for Mac OS X 10.6.8 and newer, compatible with Mac OS X 10.9. The user’s manual (PDF) is included.
<a href="http://www.fontlab.us/downloads/installers/TR4WinFull.exe">> Download TransType 4 for Windows</a>Version 4.0.1 build 5095 for Windows XP and newer, compatible with Windows 8.1. The user’s manual (PDF) is included.
<a href="http://store.fontlab.com/index.php?option=com_mijoshop&view=category&path=40&Itemid=232">> Buy TransType 4 (US$ 97, upgrade US$ 39)</a> New cross-platform licenseTransType 4 has a new license: the standard license is for a single user and allows you to install the software on a maximum of three devices (computers). The same license and serial number works in both the Mac OS X and the Windows version of TransType 4 — i.e. as a single user, you can purchase TransType 4 once, and with your serial number you can install the app on, for example, one Mac computer and one Windows computer (no more than three devices in total).
Prices: US$ 97, upgrade US$ 39The full cross-platform single-user license of TransType 4 costs
US$ 97. Upgrades from any previous version of TransType, TransType SE or TransType Pro cost
US$ 39.
If you discover any problems, please report them via
<a href="http://store.fontlab.com/index.php?option=com_fss&view=main&Itemid=220"> support page </a>.
