I've just tested it, and it works. With the option Tools / Options / Outline Font Editor / Export outline font into VFB file enabled, if you choose Image / Place Into Font, the dialog box about assigning Unicode indexes will appear, when you click OK, then in the next step you’ll see the autotracing options, and once you click OK, a save dialog will appear where you can save a VFB file. You can then open the VFB file in any compatible font editor (FontLab Studio 5, TypeTool 3, Fontographer 5, FontLab VI, RoboFont with vfb2ufo installed).
