I just purchased TypeTool 3 and am very inexperienced in modifying fonts.
Is paragraph leading stored in the font file?
If so, is it possible to open a common font (such as Arial Narrow) and create a custom version of this font where the paragraph leading is smaller than the default?
I am working with a program that does not allow me to adjust the paragraph leading so I was thinking that if this is indeed possible then it would be a solution to my problem.
Thanks.
Ray
