Posted by: eleuteruiz
Hmm... your message is not very clear. I would suggest to try these steps:
- make sure SBL is rightly installed in the system (you can check this in Font Book)
- are you trying to write Hebrew in Mellel as Unicode Hebrew? This means usually that you use a Hebrew keyboard (you know, System Preferences / International / Keyboard menu / there you need to have a Hebrew kbd checked - Then you have to choose this kbd, normally by clicking in the menu bar on the icon with the flag).
It simply SHOULD work... Or perhaps you could be more specific in describing your difficulties.
